EZ-B V3 Configuration icon EZ-B V3 Configuration — Manage EZ-B hardware settings: edit Bluetooth name and apply updates to restore altered configurations. Try it →
Motor Controller For 24v Dc Motor
Motor Controller For 24V Dc Motor
I've been reading up and not quite sure which is correct for me, sabertooth, kangaroo, hbridges, and that easily work with the ez-b. It seems there are a lot of post, but refer to other posts and each has a different way of working but seem to have a few buts. If you have this then use this and now I'm unsure. My original thought was a sabertooth.
I have 2 24v dc motors 8.9amp
My battery is two 18v in parallel getting 8ah
I am looking for speed control, I'm going to use the moble app, but might want to switch to a game remote.
Is the sabertooth the correct and easiest way to connect to the ez-b? I was at the Robotshop looking and there are a lot of choices. https://www.robotshop.com/en/medium-power-motor-controllers.html
Thanks
Why not go for the easiest sollution... Install esc's. They come for brushless or brushed motors, cheap, high performance and compact.
Here's a small overview:
Hobbyking - Esc's
Good luck,
Dave that sounds good. How do I contact you? I don't see a PM option here.
Thanks, DAn
Hi Dan,
My email is dschulpius at gmail dot com
Replace the at with @ and the dots with . LOL ;)
Ireland
Have used this motor controller in a number of projects . To connect to EZB use two relays to select direction and a servo motor to adjust potentiometer if you need to adjust speed. Ideally suited to test run motor with manual controls ( select motor direction and speed using switch and potentiometer ) without use of EZB
40Amp 12v 24v 48v Variable Speed Drive Motor Controller Reversible Control CCW
