Waveshare Bus Servos icon Waveshare Bus Servos — Control Waveshare servos (TTL/RS485): set position & speed, release torque, read position. RTS option for converters; reverse-engineered protocol. Try it →
Netherlands
Twitter YouTube
Dj?
Ditto I also would like to know specific how to on that. Also if I can choose what amperage is considered stalling because I'm sure with my bot weighing in nearly 20 pounds heavier I'm sure it will draw more.
Netherlands
Twitter YouTube
Anyone?
Humm ? I can't get that one to play so I can't watch it .
Netherlands
Twitter YouTube
@ww321q
At some point he just says omni's got motor load detection so if the load gets too high, he backs up.
I think that's important to have as the ultrasonic sensor will miss objects that are to high or low to reflect the sound back . J.W.:)
Hmmm interesteing concept
The way i would consider trying it would be to use an amp meter hooked to a sencer of some kind i think i have hurd of sencer diodes that respond to current flow if there is nothing like that i would try running the motors power lead though like rap the wire with another and monitor the power change in the coil it may not be a big change and probly vary little powor in the coil but there would be some and it should change as the motor draws more
in theary in my head dont know if it would work as i have not played with that stuff yet but i feel it would work lol
It works we have seen dj and other members do it , just couldn't remember where the how to tutorial was.
