Questions:
Which type of 12 volt dc motor can lift more? Brushed or brushless?
What is a good heavy lifting motor that can be reversed?
I need to control 12 of these for at least 2 hours, what battery(ies) is best?
I need this to be relatively light
Tiny Yolo2
— Real-time TinyYolo object detection for ARC Camera Device: tracks 20 classes, populates camera variables, triggers tracking scripts, 30+ FPS in HD.
Questions:
You'll want to look into gear ratios. Brushed motors are more common and you can get them in a variety of gear ratios
All motors can be reversed
The number of amps of your battery will determine how many hours your motor can run based on the number of amps of your motor. For example, a 2 amp motor can run for 1 hour on a 2 amp battery. Although it's more accurate to use Watts.
Okay
PS, please use descriptive subjects when creating new questions. I changed your thread subject as an example
Hi rc start tofinish- look at servocity.com robotzone servos and gearboxes plug up to ezb and have very high strength. Lithium 12v 9.8 ah batteries are available on eBay 40 bucks each and lithiums are very light for output.
depending on your robots overall current draw , 2 -4 battery packs should fit the needs in your ballpark
