Inverse Kinematic Arm icon Inverse Kinematic Arm — Control robot arms with inverse and forward kinematics, converting X/Y/Z positions into joint motion and reporting end-effector location. Try it →
What H-Bridge are you using for the stepper? A lot of users have had problems getting steppers to work with EZ-B, although @bookmaker32 figured it out with a little additional circuitry. See post 14 in this thread: synthiam.com/Community/Questions/6183&page=2
It's a L298N H-bridge.
Haven't we had a discussion before on whether or not an H-bridge would work as a motor controller for a stepper motor?... I was under the impression it won't work or was at least a good challenge...
Wouldn't it be easier to just use a basic servo for your steering mechanism?
After further digging I believe you're right @thetechguru. I'll play with it a while and if that doesn't work I'll go the servos.
Thanks to both of you!
