Horizontal Servo icon Horizontal Servo — Mouse-drag horizontal servo control with configurable min/max limits, center/release functions, multi-servo mirroring and direction invert. Try it →
I am building a robot that weighs about 15KG. I realized that the continuous rotation servo motors will not be ideal to drive the base wheel I am considering a 12V DC motor to do this task. Now my questions:
  1. Is a 12V DC motor ideal option for the base wheel? If not could you make some recommendations. 2)Assuming the 12V DC motor is the best option, How do I get the EZ-Robot to control a two 12V DC motors?
  2. How do I go about connecting it to a 12V power supply?
I will appreciate any feedback feedback.
To answer your questions...
  1. 12v motor would be fine for a 15kg bot (depending on the motors size, gearing and torque output)
  2. You need a motor controller like an H-bridge or Sabertooth motor controller
  3. The motor controller powers the motors... The 12V battery is connected to the H-bridge or sabertooth and then the h-bridge is connected to the motors... The ezb4 controls the motors through the H-bridge via a script or Movement Panel in ARC...
