Smart Variable Watcher icon Smart Variable Watcher — Efficient ARC Variable Watcher - lower CPU for large projects; slow initial array render but faster updates; shows name, type, value, length Try it →
Movement Pad + Continuous Servo Movement Panel
Update my ARC software that has the movement pad in the mobile interface. How do I get that to control the movement of the continuous servo movement panel, so I can drive the wheels or is there no scripting to link it?
There is no script to link it. Hover over blue question marks to read about the options. Look at included robot example projects for more information.
You will notice the servo Movement Panel now has speed adjustments. When you use the mobile control on the PC, the speed adjustments move in real time to show you what's going on.
Try it and it'll make sense:)
