Speech Script icon Speech Script — Run custom scripts when speech starts/ends to sync servos and LEDs to spoken $SpeechTxt, with loop support, stop button and logs. Try it →
Moving 2 Servos With Personality Generator
Hello to All,
I have 2 "Eyes" mounted on 2 servos. Each servo is connected to an output via Multi servo (D0 and D1).
I assigned servo D0 as Master, and D1 as the added servo. Both max and min settings are the same. If I move the servos with the horizontal panel, servo D0 and servo D1 move together. All is fine.
My problem is if I use a Personality Generator to move D0, D1 does not follow. I call D0 to move to a setting and only D0 servo moves. I tried looking up why, but can not seem to find anything referencing this issue. Is there a way to set up the Personality Generator that will run both servos together?
Also in the servo setup, I tried using V0 as the master and D0 and D1 as the added servos. That fails to work also.
I didn’t see a need in copying the script. Can anyone give advice?
Ron
No no I don't deserve the credit:D The A.I. deserves the credit - he had the answer in his response
If needed, I will respond to AI in the first person from now on.
FYI, I used the Relative servo with the Personality Generator and all is working well.
The ai won't respond more than once. it provides links to information to your question. Impressive, isn't it? One day he may start responding. But for the time being, less is more:)
