Hugging Face icon Hugging Face — Connects your robot camera to Hugging Face AI models for vision chat, object tracking, classification, captioning, and autonomous movement. Try it →
Are you sure that you don't have another sound file or a text to speech script playing when you try to play the MP3's you mentioned? If two files try to play at the same time, that can cause the EZ-B to disconnect.
hi steve g
no i did merge from the original jd ARC.cause the jd didn move with the original ARC.192.168.1.1:23 mine is 192.168.0.1:23 but i wil check for sure.
no doubles files or in any text
Sounds like a misconfiguration in the project. Can you post your project here so we can review it? I recall this happening before to you that I helped, due to an infinite loop of scripts in the auto position.
it works with my other jd,i send rapport
I am not asking for a report - please post your project.
If your JD is disconnecting - and the other is not. Perhaps it is one of the following
  1. power pin needs adjusting because the robot is disconnecting when moving. See this tutorial: https://synthiam.com/Community/Tutorials/45
  2. network issues. perhaps the router and/or wifi is saturated on that ezb channel
  3. the project is configured incorrectly
As requested, please post your project to be reviewed.
Use the "Choose file" the same way you do when you upload a picture, only difference is you select the ARC project instead of a picture. You will find the project under "Projects" in your ARC file in your computer.
