Set Digital icon Set Digital — Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only. Try it →
Mp3 Player Help
Mp3 Player Help
Hi all Im trying to connect up a mp3 trigger to my ez b , I know it has the built in system as well but i need to use two types of sound fx for johnny 5 one that is a ext mp3 player is also connected to the lip light circuit on the robot, i will then use the ez b built in for fx sounds so that will not effect the lip light. the mp3 im trying to use is https://www.microelectronicos.com/datasheets/WT5001.pdf
but im doing something wrong and cant work out what. Any advise would be great. thanks dave
Thanks for your help all and dave im going to get one of the sparkfun boards and use that , like u said i want to use that one for voice files so need to trigger them with servo actions and so on. Your B9 is amazing as well.
