Arduinocoms icon Arduinocoms — EZB v4-Arduino I2C bridge for ARC: supports custom C# code and reads gamepad or Wii controller inputs for robot control Try it →
I run mine through a Sure 2x25 amp. I couldn't find speaker specs in the MP3 trigger documentation.
Also use a Ground Loop Isolator to protect you MP3 trigger if using any cheapy amp..
Certain amps back feed V+ and have been known to pop/fry MP3 triggers.
I put an 8ohm .1w speaker it work but you have to struggle to here it
What did DJ use?
I used the speaker from the Wall-e
The MP3 Trigger documentation might mention what ohm/wattage speaker to use. Those little speakers seem to work fine for me:)
OK
thanks
I just purchased a 8ohm .5w should be a little louder
