Brushless Motor Movement Panel icon Brushless Motor Movement Panel — Control brushless motor controllers (hoverboard-style) via EZ-B: configure direction, speed and optional brake ports for DIY robot movement. Try it →
Resolved Resolved by ptp!
Mqtt Conecting
i am trying to use the MQTT plugin with no luck. I have a host on 192.168.2.8 and so far am just hitting the connect button but its timing out with 'uPLibrary.Networking.M2Mqtt.Exceptions.MqttCommunicationException' was thrown. Then high cpu use and a task kill to get back full operation? This is on a Tiny, if I can get this working I plan on getting a /4 also and a SSC32 to help split the power. I am 3/4 thru an Inmoov build and want/need MQTT for openhab connection.
Thanks all
Certainly, someone can help. However, we'll need more information about your setup. What do you mean by "host"? i.e. what broker is it? What are you subscribing to? Is it a broker?
What plugin are you using? The MQTT Broker or MQTT Client? Did you configure the IP Address in the client? Does the broker require authentication?
Here is the MQTT Client plugin: https://synthiam.com/redirect/legacy?table=plugin&id=170
Here is the MQTT Broker plugin: https://synthiam.com/redirect/legacy?table=plugin&id=169
Which one are you using?
The SSC-32 is a servo controller, and can be controlled using the SSC-32 control. You can find out more about the SSC-32 by pressing the ? (question mark) on the control and viewing the manual page, or view it here: https://synthiam.com/Tutorials/Help.aspx?id=216
The SSC-32 does not directly communicate with MQTT. Can you provide more information about what you're goal is? It'll be easy to setup once we know:D
Thank for helping However, we'll need more information about your setup. What do you mean by "host"? i.e. what broker is it? What are you subscribing to? Is it a broker?
It is a broker at 192.168.2.8:1883 and has been running for a few years.
Trying the client and IP is in the config. No authentication on the broker. And there is a RFM69 arduino radio network sending hundreds of msgs thru it.
The SSC-32 does not directly communicate with MQTT. Can you provide more information about what you're goal is? It'll be easy to setup once we know Grin
:) thanks I know. I am thinking, using a tiny and full/4 with a SSC-32 will let me run a Inmoov as far as power goes. The docs say the SSC-32 will work with the Auto Position panels is this correct?
Thank you
  1. What broker software & version ? 2 )operating system you use on the host ?
mosquitto Version .15 Running on a PI 2 with Raspbian wheezy
Greg,
Version 0.15 is very old:
although is not a big issue (at least for home users) there are some security issues:
I tried the mqqt client plugin with my mosquito server (1.4.12) and no connection issues.
try to connect and check your server's log:
tail -f /var/log/mosquitto/mosquitto.log
next step check ARC windows's firewall and connectivity to the mosquitto port.
last effort: update the mosquitto version.
Thanks ptp for helping
Looks like the EZ computer can reach the MQTT server
PS C:\Users\greg> Test-NetConnection 192.168.2.8 -port 1883
ComputerName : 192.168.2.8 RemoteAddress : 192.168.2.8 RemotePort : 1883 InterfaceAlias : Wi-Fi SourceAddress : 192.168.2.54 TcpTestSucceeded : True
And I looked in/var/log/mosquitto/mosquitto.log but no file there, might be the older version I have. Looking at the log I installed it on 8-15. Looks like I am not one to upgrade when it's working. So I might need to upgrade, but I am getting this so more work to do.
sudo apt-get install mosquitto Reading package lists... Done Building dependency tree
Reading state information... Done mosquitto is already the newest version. 0 upgraded, 0 newly installed, 0 to remove and 12 not upgraded.
After some work I get this after a upgrade pi@raspberrypi ~ $ mosquitto 1497739370: mosquitto version 0.15 (build date 2017-05-29 22:37:10+0000) starting 1497739370: Opening ipv4 listen socket on port 1883. 1497739370: Error: Address already in use
This version does does not match the build date? I might add the latest windows MQTT clients connect with no trouble.
Greg,
you need to do:
sudo apt-get update
apt-get update downloads the package lists from the repositories and "updates" them to get information on the newest versions of packages and their dependencies. This command does not install or upgrade any packages.
sudo apt-get upgrade
installs newer versions of the packages you have. After updating the lists, the package manager knows about available updates for the software you have installed. This is why you first want to do apt-get update.
