Sharp IR Radar icon Sharp IR Radar — Radar-style Sharp IR scanner for EZB ADC: sweeps sensor, displays distance dots, logs ADC voltage, and can steer/avoid obstacles via Movement Panel Try it →
only one object at a time
so i can tell it to track red objects and then it will track an object and make the x-y variables and then it will track the other one and so on and if not what can i do
Just like your eyes, the robot can only track one object at a time.
ok now i understand is there a way to do it easily
ARC can track one object at a time. You can specify multiple tracking types - but only one will be tracked at a time.
can another application integrate with ARC to do it
Is there a radar that judges size as well distance? Or a sensor that judges size? If so, you could, IN THEORY, write a script that defines objects by size (as well as some other conditions as well) and have it take tracking priority based on object, or object and distance.
I don't have my ping hooked up yet so I can't test this theory. (next few days I swear it)
