@nomad.
Yes that is normal. If you look at the video DJ made in this thread you will see purple outlines sometimes with a black one too on his yellow duck and green frog. The black outlines flash up quickly but they are there. How many multicolours do you have set up?
steve S
i set up 4 colors
Okay. I think it does it when the camera detects two instances of the same colour or colours you have saved. I remember seeing that too when I saw the video the first time and noticed it with my camera.
steve G
that a great help thanks,learn something. in the video ,script has only 3 lines for it to work.is that all i need?
To do what DJ is doing in his video, yes, you only need the three lines of script he used.:)
steve G
you just solved my complete problem.i did use desame as in the video. it didn work.first i though was light was to dark but no. when i see the cam working,jd sees all colors more then ones. got alot off robots here.so i need to find a place where no saved colors, are to bin seen.
thanks steve g
Patrick, Yes, try training colored objects on a white wall without any colors, and maybe recognizing colors on a neutral colored background. I had to adjust the color wheel numerous times to achieve my results.
steve S
i notest the cam sees all colors no matter how small they are. gonna by me secondhanded screen from cinema orso. i got now blue,red,green and yes behind a whit screen. one problem still excist is the volume is very low,i cant hardly hear it.
