ROS2 Connector icon ROS2 Connector — Bridge ARC to ROS2 via rosbridge: publish/subscribe topics for cameras, servos, ports, NMS, variables, scripts, and movement. Try it →
Multiple Ez Networks Appearing
This is related to a previous question but that seems to have disappeared from the forum (it has been a few weeks).
Anyway :-)
I'm showing multiple networks when I attempt to connect to my boards:
EZ B V4-2A EZ B V4-0F
It seems like one board will only work with one network. The other board with the other.
I would think there should only be a single network appearing.
Any ideas what's going on?
Thanks,
  1. Scott
Are they both in AP mode? If they are then each one will show up.
Also, here is a list of every discussion that you've started, to find your lost thread: https://synthiam.com/User/mulberry/ForumPosts
As Bob said, each EZ-B v4 will host it's own network. If you have two EZ-B v4's, you will see two EZ-B v4 WiFi networks. If you have 953,321 EZ-B v4's, you will see 953,321 EZ-B v4 WiFi networks.:)
Thanks BHouston and DJ.
Daniel
