TCP Clients icon TCP Clients — Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections. Try it →
Multiple Movment Panels
hey dj i want the movment panels to have board control so that i could connect 5 ez-b and control each one alone also i want to be able to select which movment panel the joystick use and the camera and the command forward() to have a parameter of which board it uses
