Can you allow multiple movement panels in ARC please. I have the roomba panel added but then went to add AutoPosition to control a robot arm and received a you are attempting to break the time space Continuum error
PWM Servo Ramping
— Smoothly ramps PWM servos on EZB D0-D23 via Vx-to-Dx mapping for natural, gradual motion without snapping.
Under servo there is one, and under movement panels there is another
under servo, as many as you need can be added = auto-position movement panels
After you select a servo, you can also pick a connection - connect 0 - 4
EzAng
Add the Auto Position non-movement panel.
Arc -> project -> add robot skill -> servos -> auto position
If you think about it, you’ll realize why there logically can only be one movement panel. Check the manual on what a Movement Panel is as well
Aggh OK I did not know that existed. Thanks EzAng That is exactly what I was looking for. OK not a required feature any more :-) Time Space saved again. Please close request.
This was moved into a question
Thanks Jeremie,
Your community post was liked by 'Jeremie'.
I added an entry in the manual for each of the Auto Position robot skills so people will know there are two of them.
Movement Panel: https://synthiam.com/Support/Skills/Movement-Panels/Auto-Position-Movement-Panel-Gait?id=16057
Non Movement Panel: https://synthiam.com/Support/Skills/Servo/Auto-Position-Gait?id=20314
