Hello ,
Quick question for you all... Let's say I've written all the logic and functionality and it's working as expected. Can I disconnect the ezb from the computer and allow the robot without and additional input?
MPU6050 Accelerometer Gyro Temperature
— Reads MPU6050 gyro, accelerometer and temperature via I2C, initializes and returns data on-demand to EZ-Script variables using ControlCommand RunOnce
Hello ,
You must operate teathered via wifi either connected through a network or in a private network to either an android/iPhone or windows pc running ARC.
The processing required for vision processing, speech recognition, GAITing and other advanced robot features require computation far beyond the level of a microcontroller. Additionally, if you could create an embedded computing module which has the power of a PC to attach to your robot - would be silly due to the energy consumption vs weight ratio. The robot would weigh as much as a computer and therefore require additional power. Bigger batteries, bigger motors, bigger batteries, bigger motors, rinse, repeat.
Also, embedding PC comparable processing potential into an ez-b style robot controller is very expensive and the ez-b would cost as much as a PC.
Thirdly, the chance of you upgrading to a newer phone, tablet or PC is much higher than upgrading your robot controller
So in short, it's very cost effective, energy efficient, and strategic to offload the processing to another device.
Understood, and it makes a lot of sense.
Just use one of those micro computers like they use in cars, that will require just a 12v source, and it wont weight that much for the robot. Od fcourse the robot brains should always be with robot!
