Kinect Body Control icon Kinect Body Control — Control robot servos with Microsoft Xbox 360 Kinect body tracking; map joints to upper/lower body servos with smoothing and pause control. Try it →
My 3d Design For The New Io Tiny Board
My 3D Design For The New Io Tiny Board
This is just a simple mock up... I am sure it will need tweaking. I designed it according to the board dimensions that @Jeremine posted in another thread ( https://synthiam.com/Community/Questions/9378 )... Since I actually don't have an IoTiny to work from, I am sure (as mentioned) I will need to adjust the design a fair bit... Io_Tiny_BetaV4_part1.stl Io_Tiny_BetaV4_part2.stl
Looks good, will you share the sti files once you have a Lotiny and adjust the design to suit.
Chris.
May be Jeremie would send you a pro-type to work with? ;)
First, it looks awesome!
But, how did you manage the tapered edges/sides in TinkerCad? Or does it just look like there is one?
Post the files and I'll try it out:)
@DJ... They are not finished (there are probably some errors in the stls as well) but I will post what I have so far..
@Justin... I actually used the ezb4 STL shell(s) and manipulated them... I haven't figured out an easy way to filet or taper edges yet in TinkerCad... I know that option is in OnShape, however...
Hey @RR, that's a nice enclosure!
Here's a bit of feedback:
The length dimension needs to grow a little from ~40mm to ~45mm
The top enclosure seems to bottom out on the barrel jack, so it may need to grow in height or a cutout may need to be added.
The cutout on the camera/i2c/speaker connector side may need to go further to the edge
