Sherpa-ONNX Speech To Text icon Sherpa-ONNX Speech To Text — Offline continuous speech recognition with wake word support, custom phrases, and real-time transcription using sherpa-onnx models on ARC Windows. Try it →
Germany
Resolved Resolved by Steve G!
My Battery Is Low
hi there, Im working with the EZB-4 and 21x servos + a lot leds, camera and sensors.. the robot needs a lot power in action. in the same second If my robot says: "my battery is low", he collapse.. I have no time for a reaction. its not good for the optical look.. I dont want scratches.. or a broken arm.. you know. So I need to find a way to programming a better "battery is low warning". or a optical LED.. the best and coolest way is a live status inside the EZ-Robot Software..
thanks Marty
I'm not near a computer right now as I'm out of town and didn't bring it with me, but something like what I posted below should help...
#This script will trigger when the battery hits 6.9 volts.
#Change the voltage to what you want it to be.
:Loop
If($GetVoltage()<6.9)
#Enter your  ControlCommand for your  Auto Position action here.
EndIf
Sleep(500)
GoTo(loop)
I'm not 100% sure of the syntax in the code above (maybe Rich could confirm), but it should be close enough.
EDIT. Looks like Rich beat me to it.:)
The If condition needs wrapping in the brackets, you only have half in it. So
IF($voltage = 6.9)
However, a less than is better in case something drains it below 6.9 before the script spots it.
Looping the script with a sleep to constantly monitor would help. Or a waitforchange()
You don't need to assign the GetVoltage() to a variable. You can use it by itself.
See post #10:)
@Rich.
Yeah, I just saw your post. Thanks for clearing that up. I changed the code above to reflect what you said. I have a hard time as it is scripting with a computer, never mind doing it from memory, lol.:P
@Smarty.
Rich has you covered on this one with the script example he posted. That will get you sorted. Just to explain, in the example, the "x" in "$x" is where you can name a variable to anything you want and use it in your scripts, but not always nessasery.:)
Germany
yahoooo! perfect :-))
thanks a lot
Germany
variable not defined in line 2.. sick
IF($voltage = 6.9) or If($GetVoltage<6.9)
is not working
#15
$voltage needs defining first.
$voltage = GetVoltage()
Or, use GetVoltage() correctly
IF(GetVoltage() < 6.9)
Germany
#16
hmm.. it says always: variable not defined for both. can you explain what you mean with: $voltage needs defining first. please for dummies:D
