Speech Script icon Speech Script — Run custom scripts when speech starts/ends to sync servos and LEDs to spoken $SpeechTxt, with loop support, stop button and logs. Try it →
My EZ-Cloud Files
Hi Synthiam,
I am having trouble accessing and deleting a troublesome project in my EZ-Cloud.
I added a multi colour tracking variable to the default EZ-Robot Roli project and uploaded to my EZ-Cloud so I could use the mobile app to track and interact with that multi colour variable.
When I opened the ARC App and tried to download the project I got the following error and my app crashed. "Server was unable to process request. ---> String was not recognised as a valid DateTime. Error, check application log"
I have tried checking the application log, but it doesn't have any further details and crashes before I can view any error.
Next I tried to delete the project from my EZ-Cloud via ARC, but it gave me the following error. "Version: 2020.01.05.00
System.NullReferenceException: Object reference not set to an instance of an object.    at EZ_Builder.EZCloud.FormEZCloudOpen.xSlhWuqQ5an(EZBuilderFileInfoV3  )    at EZ_Builder.EZCloud.UC.UCEZCloudFileItem.EbChVTPLYDP(Object  , LinkLabelLinkClickedEventArgs  )    at System.Windows.Forms.LinkLabel.OnLinkClicked(LinkLabelLinkClickedEventArgs e)    at System.Windows.Forms.LinkLabel.OnMouseUp(MouseEventArgs e)    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)    at System.Windows.Forms.Control.WndProc(Message& m)    at System.Windows.Forms.Label.WndProc(Message& m)    at System.Windows.Forms.LinkLabel.WndProc(Message& msg)    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)"
"label5 system.Web.Services.Protocols.SoapException:Server was unable to process request. ---> String was not recognized as a Valide DateTime. atSystem.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream"
Is there a work around to remove this project from my EZ-Cloud and is there anything I should do differently when uploading a project to my EZ-Cloud?
Appreciate your help.
Roli Rover by EZ-Robot
Roli Rover with Synthiam ARCx: drive with live video, control arms, follow faces, patrol, and program with Blockly or Python
I'm on it, sam. Stay tuned.
Fixed - your files are accessible now
Brilliant! Thank you DJ.
Anything I should keep in mind when uploading files/projects in the future?
Yah - expect the occasional bug cough cough haha. It was all on my end - a bug with a null db entry that wasn't being populated correctly. Embarrassingly enough, it was my code from a loooong time ago:P
Hahah not a problem, thanks for jumping in and resolving it for me, I appreciate it.
