File Manager icon File Manager — Displays files currently open for reading by scripts, shows only read-opened files, helps diagnose read/write locks and file access errors. Try it →
My Ez-B Isn't Powering Up
I've got the developer kit, this is my first time trying to build a proper robot. After putting in the batteries to the holder and connecting it to the power shell (the ez-b was already in the shell) it is supposed to just start up, but it hasn't done anything so far. No sound, lights, anything. I've tested the rechargeable batteries (they're new anyway) and they are working. I've checked and re-checked the cable from the battery pack is connected correctly to the socket adaptor and wires are securely screwed in. I've opened the shell and the EZ-B, and can't see any fault with the connections. I'm an electronics technician and I'm on the verge of going into work just to get my multimeter.
Can anyone suggest something that I might have missed?
Is there a "spontaneously started working" option? Instead of leaving it unresolved?
If it stops working when I get home I'm going to be annoyed :/
Check the magnets inside of the EZ-B case to make sure that they are firmly attached (if it has them). Also, I wonder if reseating the fuse solved the issue. IDK. Possibly also bend out slightly the pins for power from the base to the back of the EZ-B. There may not have been a good connection there I suppose.
The digital pins are not voltage regulated, so you can always check the digital pins for voltage to see if the same 8V is making it all of the way through the board to the pin.
No, this isnt a common problem, or you would see a lot of posts about it in the community. I suspect that there is a loose connection somewhere in the mix, probably where the connections between the different components are involved.
I HAVE FOUND THE PROBLEM!
The battery holder has such a tight grip on some of the batteries that the spring isn't strong enough to push the battery right up to the positive connection on a couple of the side slots where the holder has extra grips:P
Thanks for the help .
Thanks for the help, I'm glad that if I need help there is this forum xx:P
