Neopixel Blaster icon Neopixel Blaster — DIY NeoPixel Blaster for ARC - open-source controller for up to 8×80 LEDs (640), port‑0 onboard RGB, color control via ControlCommand Try it →
My Ez-b Needs Service
My Ez-B Needs Service
Waited over a month to get my kit. First time I plug it in, needs a firmware upgrade ... attempted to do so and got this result:
Firmware Updater Version: 2013.03.18.00 5/16/2013 8:23:44 PM - Begin
Attempting connection on COM6 Connected to COM6 at 9600 EZ-B reports EZ-B Firmware V2 Connected
Welcome to EZ-Robot!:)
This is the first time you have used this EZ-B. After this upgrade, we recommend that you take a moment to view the tutorials at www.ez-robot.com/Tutorials. Nearly every question you have regarding EZ-Robot is answered in the Tutorials.
Press the HELP menu option to watch a video about this Firmware Upgrade process. Otherwise, press UPDATE when you are ready.
5/16/2013 8:23:55 PM - Sending bootloader Starting Boot Loader...
5/16/2013 8:24:03 PM - sending ping 5/16/2013 8:24:04 PM - sending ping 5/16/2013 8:24:06 PM - Sending bootloader I am EZ-B BootLoader. Gimmie Firmware!
5/16/2013 8:24:13 PM - Step 1 of 2) This process will take 2 minutes. The status bar will display progress.
5/16/2013 8:24:13 PM - Updating... (22,656 Bytes) 5/16/2013 8:24:35 PM - Uploaded
Have not been able to connect to EZ-B since.
Germany
#25
Ok, guys, finally eyeroll figured out how to uninstall Toshiba BT Stack and install the MS BT stack. The connection was found and the update worked fine, even though I have two COM3 interfaces confused, where one of them is for the EZ-B. But i am able to connect and control my first servos. Thanks for your support!
