Connection Diagnostic icon Connection Diagnostic — Diagnose EZ-B Wi-Fi connection issues with verbose EZ-B communication logging, ping tests, log export and diagnostic reports for Synthiam support. Try it →
Gibraltar
I'm so very sorry if I offended anyone, I was just trying to show that there are easier 3d programs out there.:(
@Techno, a good start. There is a little bit of a hole in the ping sensor which you really should pay attention to as knocking little things like that on the head early on will make a huge difference with your designs later on. Other than that it's good work, keep at it.
@bborastero, I've been using AutoCAD and other Autodesk products professionally for around 15 years now, I've tried out most of the 3D cad software (with the exception of solidwork as I can't get a decent trial version) and personally I use 123d regularly over the software which I have paid over 2,000 for due to it's simplicity and ease of use. I have tried sketchup and couldn't get on with it. Point being, you may find sketchup easier but it isn't the case for everyone:) I'd always advise people to try everything and see how they get on with it but ultimately I'd recommend 123d over anything else for basic 3D cad work (for more advanced stuff I'd recommend AutoCAD2014 and Inventor however I'm sure others may recommend SolidWorks or some other CAD software).
@bborastero- None taken friend. I do appreciate the sharing. I started out using sketch-up but had issues importing the stl files it produced into ARC's Bit Builder. I then tried 123D and never looked back. I'm actually about to try some other programs here real soon. Blender for one. The names of the others escape me at the moment. I know Blender isn't easy but I see it mentioned a lot in the 3d printing forums.
#15
That's awesome @Technopro! Nice work. Your ping sensor placeholder looks really no different than the one i made for designing the revolution parts:). What @Rich said about keeping good habits in your design is really good advice. Keep in mind he doesn't mean everything needs to be super detailed. Something like a placeholder only needs to be detailed where it is important. Time spent on a placeholder is time taken away from your actual part.
#16
Yep, I didn't mean go for super detail (I tend to because I get carried away, just look at my MG90 servo place holder to see what I mean). In fact, my version of the ping sensor place holder is pretty much two cylinders on a cuboid with another smaller cuboid for the 4 pins and that's pretty much it.
The small hole I mentioned was probably due to the way it was drawn and (and I will do a quick video when I get the chance) the way I use 123D would avoid that happening, it's also a very simple method, although I wont claim it's the best as I don't know.
But as I said before, everyone has different methods and I am sure Cory, Ant, bborastero, Antron etc. all do things a different way and differently to how I do things. It's finding what works best for you really.
