Text Overlay icon Text Overlay — Overlay a variable on a processed camera image at X/Y coordinates; name the variable and attach to a specific or any available camera Try it →
Use the Contact Us page and send your request.
However, if you wanted to test the D0 port the simple way is to connect up an LED & resistor to the Signal pin on the +ve side of the LED and ground to the -ve side. Then add a set digital control for D0 and set to on. Or run the following in a script;
Set(D0, on)
mine is doing the same thing. I don't know if I did something wrong, or it just gave out. It was working fine one moment and BOOM! Nothing. But, I am not blaming the EZB because there is no proof of what happened. Probably my clumbsiness.
I got mine working. I just re-seated the cpu into the socket and ALL of my ports came back.
Good Luck!
My problem is back! I cannot understand it. blush:(
Ok, problem is now solved thanks to Robo-Doc. I replaced the two rectifiers and same thing. I replaced the diode and same thing. Then , I removed the cpu and put it back and made sure that it was re-seated and BANG! all my ports worked. Hope this works for you.
Good Luck!
:D
Great Mel! Awesome your back up and running. Are you going to mark this one answered ?
I can't mark it answered because I did not start it.
