Serial Terminal icon Serial Terminal — PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex Try it →
Need Help Extending Wires To Drive Train On My Omnibot
Hey guys, I've adapted the chassis of an Omnibot 2000 a bit and I need to extend the wires to reach the wheels/motors. I'm going to put in my EZ-B goodies when they arrive but it's back ordered and my sister's class needs a mascot for their new robotics team next week. Any advice?
I started with a glitchy omnibot but after some soldering repairs and a new capacitor the original system worked great, UNTIL I cut the wires to the drive train. I just attached a longer set of wires with a splice but now I've got no response from the wheels. I tried a wire nut and then a shrink tube but no response. I'm no electrical engineer, I learn by burning things up. Can anyone tell me what's wrong or suggest a work-around? I just need a solution that will last for a month until EZ-B arrives. Also, I admit it really bugs me that I can't get it to work myself. Maybe the new length and splice create a power drop? ANY ideas welcome, thanks.
Jenn
#25
God bless Texas. Greetings from Buster, Buster Jr. and Roger the bookmaker in Kerrville Texas.
#26
Hey Bookmaker,
I think this thread is over but I couldn't resist saying howdy to a fellow Texan, especially one so close to River's Edge (I think it's called 1011 now) and those yummy burgers. See you on the community boards.
Jenn
#27
That's awesome Jenn, I'm glad you found the issue. You are welcome! I'm looking forward to seeing how your robot progresses.
#28
Hello Jenn,
What did you use to extend the base?
#29
Sfoy, in case you are still around....I used a heavy duty plastic file storage box with an open top from Ikea. I cut a wood top (3/4" birch) to enclose the box and routered the edges to transition from the file box to the Omnibot frame. In the front of the box I cut a square around the vented center and added trim, hinges, and a lock to create a locker instead of an inaccessible base.
