Lidar-Lite Laser Module icon Lidar-Lite Laser Module — Laser Lidar-Lite ARC control reads distance, velocity and signal strength (0-40m+) via EZ-B v4 i2c, setting EZ-Script vars for robotics Try it →
example interface code
Mike, it all sounds like a great idea. I hope you find a way to get this done. I wish I could help but have no knowledge of how to write this code.I'd be one of the "common" people who would benefit from this.
I have one request; could you use punctuation in your posts? One continually rambling sentence that goes on for line after line is hard to read, hard to understand and in my opinion disrespectful to the people your trying to communicate with. Also it's actually in the forum rules that you need to have legible forum posts. I really would like to follow your ideas as they seem very interesting. :)
I'am sorry if I disrespected you in any way I did not mean it. I was at work and trying to answer something in a hurry. But a disrespect is going a little far don't you think. People use improper English everyday it's not a disrespect(your should be you are or you're)
Mike, are you an experienced c++ programmer? I'm not failure with YARP, but like I said, if you use the SDK and you have programming experience you can probably interface the EZb controllers with your YARP.
Whatever Mike. You're (woops) Your disrespect was not towards me but was general and subjective. So, I guess it's all about you and whatever is easier for ya. The heck with who ever is trying to read your request for help. I asked nicely and ya couldn't handle it. So, have a good stay, good luck with getting the help you need and type away and away and away and away.
Oh, BTW, all your posts in the past 2 years except the very first one haven't had any punctuation in them, ever. Not just this once when you were trying to answer a question from work.
@Justin, from his past posts it seems like he has little coding experience, a good idea and wants someone to do the coding for him.
Thanks everybody, I figured out what to do. Basically, a friend and I wrote a c sharp wrapper to yarp, that only uses the functions I need, leaving out all the confusing code. I have some coding experience but little to no robotics experience. I"am learning fast!
