Soundboard (PC) icon Soundboard (PC) — Play and manage MP3/WAV sound effects from a PC soundboard, load tracks, trigger or script playback (one file at a time), export and automate. Try it →
Need Help Testing The Elechouse Tlg10ua03 Uart-wifi ?
Need Help Testing The Elechouse Tlg10ua03 Uart-Wifi ?
After Midnight Thursday, 14 March 2013
Good Morning EZ-Robot.com Hardware Team !
 Last week I received my ElecHouse UART-WiFi Kit, and got it Connecting to my Home Router with help from Robot-Doc, who  led me to the TLG10UA03,
ElecHouse UART-WiFi
 I have attached my Screenshots and Test Procedure, "13-Mar-2013 ElecHouse WiFi UART Serial Terminal Loop-Back Test.doc", and my ARC File of the same name.
 I am using DJ's New Serial Terminal within ARC; seems to WORK GREAT, but I need to LEARN MORE on its proper use ?
 My Question is, Exactly Where Do I Loop-Back the WiFi Module; I tried Tx-to-Rx with No Success ?
Thank You All & Best Wishes,
[email protected], 602-246-1246(H)
13-Mar-2013ElecHouseWiFiUARTSerialTerminalLoop-BackTest.zip
13-Mar-2013WiFiUARTSerialTerminalLoop-BackTest.EZB
#25
Thank you DougPope but I can't access the module in anyway, the config application does not recognize it any longer, for some reason that I can't explain. When I click search, it just doesn't find it, while I can connect through serial terminal.
United Arab Emr
#26
Did you press exit first ....as usually it gives me exit from transparent mode Than search ...it finds it.... Do not ask me why. It happens to me
#27
I did that and it works once, then I reconfigure everything but something obviously went wrong since now I can't access it any longer.
United Arab Emr
#28
Try to quit config tools reinsert the USB and restart the software ...I am sure your tried.... but just may be ....it is something I always do with windows!
#29
I even tried on a differrent computer... I'm desperate now. Does someone know what the jumper is meant for ? Is pulling it off a way to hard reset the module to its factory settings ?
#30
You might be able to reset the module by connecting Gnd to pin 4 then apply 3.3Vcc to the module for a second or two then disconnect pin 4.
#31
Thank you so much. Just a question... where can I find a diagram showing which pin is pin 4 ? And are talking about the ground on the USB adapter board or the Ground on the Wifi board ?
I guess pin 4 is not VDD otherwise it would create a short. Unless you mean that I should connect the Ground pin on the wifi module to the VDD on the usb/com board and then reconnect the jumper on 3.3 volts for two seconds, is that what you mean ?
Thank you again.
Elfege
#32
The diagram is in the WiFi document that is downloaded from the website where you ordered your unit.
