Tutorial icon Tutorial — Tutorial slide plugin for ARC: create, format and embed text and images per .ezb project; navigate/update slides via ControlCommand; auto-resize images Try it →
Need Help Testing The Elechouse Tlg10ua03 Uart-wifi ?
Need Help Testing The Elechouse Tlg10ua03 Uart-Wifi ?
After Midnight Thursday, 14 March 2013
Good Morning EZ-Robot.com Hardware Team !
 Last week I received my ElecHouse UART-WiFi Kit, and got it Connecting to my Home Router with help from Robot-Doc, who  led me to the TLG10UA03,
ElecHouse UART-WiFi
 I have attached my Screenshots and Test Procedure, "13-Mar-2013 ElecHouse WiFi UART Serial Terminal Loop-Back Test.doc", and my ARC File of the same name.
 I am using DJ's New Serial Terminal within ARC; seems to WORK GREAT, but I need to LEARN MORE on its proper use ?
 My Question is, Exactly Where Do I Loop-Back the WiFi Module; I tried Tx-to-Rx with No Success ?
Thank You All & Best Wishes,
[email protected], 602-246-1246(H)
13-Mar-2013ElecHouseWiFiUARTSerialTerminalLoop-BackTest.zip
13-Mar-2013WiFiUARTSerialTerminalLoop-BackTest.EZB
#57
Rich : humm... lool. There's a time to discovery for everyone I guess ! Thank you Rich... now you say it, it seems so obvious...
#58
The EZ-B bluetooth is a class 2 (33 feet) device and the only thing preprogrammed in it is the device name. It can be used elsewhere if needed.
#59
I started working on hooking up my Elechouse WiFi module last night in order to write a tutorial, and I have had limited success. I did confirm that ARC will connect without a virtual serial port by specifying IP Address and port number instead of a com port in the connection dialog. You will be asked for a password, just leave it blank and click OK. The problem is that it takes several minutes to connect and then does nothing. However, with a virtual com port I can't even get a connection at all at any baud rate.
I noticed that the main LED on the EZ-B was going out once a connection was established, so it lead me to think I might be getting a brownout.
In researching this, I found this old thread.
It appears that my connectivity issue, and the slow response and disconnect issues being discussed in this thread are because the EZ-B doesn't supply enough amperage on the 3.3v pin and you need to run alternate power to the WiFi board in parallel. It was quite late when I found this, so I haven't had time to test yet, and the other thread just ended without anyone claiming success, so I am not 100% sure that is the answer, but I will try it again as soon as I can and post results.
#60
While your experience wasn't exactly a complete success it has eliminated a huge problem with that God awful virtual com port! Something I expected to and was hoping would happen. Virtual anything is never a good idea, whoever though up and recommended it needs shooting:)
You just reminded me to see if mine has turned up yet, haven't checked if I've had any post (mail) today yet... Edit: YES it's here:)
Good find for the 3.3v issue, that saved me a headache when I fit mine... hopefully.
#61
The other thread mentioned that it should work on 5v as well, but I had even less success using the 5V lead on the EZ-B. LED's on the WiFi board wouldn't even light up.
You will still need virtual port unless you want to switch back to Bluetooth (or I assume, but haven't gotten far enough in testing yet the USB TTL) when you want to upgrade Firmware. The firmware updater does require a com port number.
Also, projects like @Doug Pope's needed it since he is trying to use it to connect to a Roomba, not the EZ-B.
Oh, one more thing to save you a headache... When hooking up the TX and RX on the USB-TTL, you hook TX to TX and RX to RX. They appear to be mislabeled on the USB-TTL. The Elechouse manual has a totally different serial board so finding that was just trial and error.
For the 3.3v issue I had just connected the power to the original USB adapter which was attached to a USB power port available on my project. Everything worked fine for several days, using the settings I recommended in my earlier post on this same forum. However for some reason the wifi module just stopped working at all and I couldn't, this time, hard reset it using the method I had used before. I wonder if we shouldn't link the ground to both the alternate power source AND the EZB's ground port. I'll receive a new module in few days and I'll see. I'll let you know.
I never succeeded in connecting through IP directly in a reliable way even though I had the correct amount of amps so I don't think this is the issue. I had control over the robot while connected through direct TCP but it was responding with a long lag. HW virtual port works fine though once you enter the proper settings and most of all once you use direct baudrate emulation.
Best, Elfege
#64
I should be receiving my WIFI UART soon. I am wondering what is the maximum rated current from the EZB's 3.3v pin. I will need 300ma MAX.
