Speech Synthesis icon Speech Synthesis — Speak user-defined text via PC audio or EZ-B v4 speaker; configurable voices, effects and speed; uses Windows TTS; programmatically callable. Try it →
Need some help with speech rec
Need Some Help With Speech Rec
Need some help with speech recognition
I have never had problems with this before but I can not get it to work at all now. I've had it running great in the past but now nothing. I reviewed the tutorial but no help. I have set up my mic and levels correctly and my Bing speech recog works fine but the EZB plugin does nothing. I look for the variable in the variable monitor and it is not present there either.
Has something changed?
#41
Thank you for your response on this, Perry_S.  I guess I'll have to wait until the next Windows Update to see if it clears up the problem.
#42
Microsoft broke their speech recognition - it’s very unfortunate because many are suffering from the issue. We don’t even know what they did that caused the issue and have been trying to figure out a work around. At this time the only advice we have is to wait for Microsoft’s fix:(
#43
Thanks for expanding on the seriousness of the problem, DJ.
#45
ARC is using the System.Speech namespace. The namespace you linked to is for UWP, which is universal windows platform - a different flavor of the .Net eco-system and incompatible. There's no way they could discontinue System.Speech, because everything using Speech is built on it that isn't UWP.
#46
Thanks for clarifying.  Surprisingly difficult to research speech on Windows 10.
#47   — Edited
Ya it’s super difficult - and Microsoft has figured out how to trick google to have old articles appear as new. I searched for system.speech recognition not working, and a bunch of articles showed up saying "5 days ago". But the article was dated 2007...
Because Microsoft tricks google to be on top with incorrect update time stamps, it’s impossible to find current messages on the subject.
I just got the same issue, windows 10 1803
No new hardware.
and no significant updates:
If the update list is correct ... I don't think is a major Windows Update fault...
I'll try to understand what is going on.
