Camera Click Servo icon Camera Click Servo — Interactive camera control for ARC: click-to-center and edge hotspots to pan/tilt servos, adjustable fine-tune and multi-camera support. Try it →
so if i understand you david pin 18 and 19 are bolt connected to the black pin on ezbv
not at all.
the black from the ezb goes to the ground pin on the arduino
The white pin goes to the receive on the arduino. It all depends on which port you you use, but if you want to use the sketch that Luis provided, the documentation is available in the tutorial.
i didn find the sketch
When I get time, I will provide a step by step video on how to make a neopixel ring work with the EZ-B through an Arduino. I just don't have time until after this weekend at the earliest.
thats great thanks david
#15
@Nomad6R, I just updated the tutorial for connecting the Neo Pixel ring to clarify that the "Signal Pins" on the EZB are connected to the RX and TX on the Arduino. Did you get yours working?
hi bhouston
i dont have one,my friend has one and was able to get it working. wiht your help.am going to see your tutorial now
thanks
