Omron HVC-P icon Omron HVC-P — Omron HVC-P ARC plugin: real-time body, hand, face, gaze, gender, age, expression and eye estimation; facial recognition via Omron software Try it →
Network Question:
Ok, here is what I have:
The ports are: Router 10.0.0.1 Desktop 10.0.0.2 MagicJack 10.0.0.3 EZB 4 (Sally) 10.0.0.4
I have everything going into the router and then going to the Internet.
I have two wifi connections. One is for the Internet and one is for the EZB. If I hook up for the EZB, I loose the other connection.
I guess my question is: How do I hook it up were they are BOTH connected?
The ports are conflicting.
#33
Quote:
"I can only connect to the internet when I disconnect the ezb4 because there is some sort of conflict."
No, the reason you can't connect to the internet and the ezb4 at the same time is because your ezb4 is still in WP mode.... As mentioned many times, once you get your ezb into Client mode you will be able to connect to the ezb4 and internet at the same time...
#34
OK, I have made a step further. I have Uninstalled TightVNC on both Desktop and Tablet. It now tells me to connect to 10.0.0.2. I tried both 10.0.0.2 and 10.0.0.1 without success. I give it the password,but it doesn't accept it. But, that IS a step forward.
My Network map shows:
router: 10.0.0.1 Desktop: 10.0.0.2 magic-Jack: 10.0.03 and Sally: 10.0.0.4
Do you think that Sally is conflicting? because she has 10.0.0.4 . How would I change that?
#35
I have tried Everything. .... I give up. I am going to let it set a while.
