Horizontal Servo icon Horizontal Servo — Mouse-drag horizontal servo control with configurable min/max limits, center/release functions, multi-servo mirroring and direction invert. Try it →
New Anomaly On D0 Signal Pin
Hello All,
After the latest firmware update I am noticing that the signal pin on D0 on my EZ B starts out in a high state. All other D pins are low (strange). I believe this is a problem with the latest firmware because I now have 2 EZ-Bs and they have the same issue. D0 is high on power connect.
I discovered this when my bot started moving (at least one of the tracks) as soon as I plugged it in (before even connected to the COM port).
Once you do connect to ARC normal control resumes (After you toggle D0 low).
v/r
Kevin
That is not bug. It is the solution for the BV4113 fix
blush Sorry DJ. Sounds good. It was pretty funny actually when my bot started doing the one leg duck thing around in circles!
Haha, i bet! It was a strange solution for the BV4113 problem:)
