Full Screen Video Player icon Full Screen Video Player — Fullscreen overlay video player controlled by ControlCommand: play/pause/resume/stop; ESC cancels playback and locks new playback until unpaused. Try it →
there is an issue with your design. nothing would connect to it. if you put the thinner piece on the outsides, and the thicker piece in the middle, it would work. You could even put the thinner piece in all 3 places and it would probably work even better.
ah .yes thats what i mean.something like this to connect two females.
maybe whit some support to,
The design of the bits is intentional for the direction of connection. Every body has female connectors. Each bit has combination of male and female connections. This allows ezbits to chain together.
The piece you showed would not benefit a robot.
i disagree whit you. how do you connect two females? how do you connect for excample the sonar or rgb to the front off rolli or jd chest? there is no male or female on the back covers.
You can use the extension cube Cube to attach the ping sensor bit to Roli's or JD's chest...
Rich is correct, you use the extension cube or extension block - both which offer slots for additional bits.
Also the sensor and block would normally be connected to a servo as well:)
