Maestro Servo Controller icon Maestro Servo Controller — USB control for Pololu Maestro (6/12/18/24) via ARC Vx ports. Maps Vx to Maestro channels; supports position, speed, acceleration, release. Try it →
Egypt
New Ez Script Command Request
hey dj sures i need 6 commands 1-to write data to a computer serial port 2-to read data from a computer serial port 3-to enable scripts to send data to each other 4-to send data to the camera's window as RGB values 5-to read data from any window that uses movement panel 6-to read data from user in ez-script please help!!!!:D ;) cool :)
You'll want to look into the EZ-SDK, which contains all of the function commands for the C# and VB controls within ARC
Load ARC, select File->Examples and load any of the C# examples to begin
im dont want it for c# or vb as i need to be able to send direct from the comand line "dos prompt" and for some reasen i cant open the sdk samples nor can i get a program that will open them on my computer many years ago i came up with a circuit that responds to the 8 bit binary data lines of the parallel printer port I beleave there is 255 dif combinations 256 if you inclued 00000000 but that one is useless lol and if i string them together the posabilaties are endless i wish to use it on many computers to control many many things many that are not part of robots things like my tv car lights ect if i program it with c# vb or others it will be way more complicated than it needs to be that if i do it with bat files
you can download the EZ-SDK by clicking on the Downloads link at the menu. The file is a ZIP file, and windows should natively open it. If not, you can use Winrar or Winzip.
For advanced functions, you can use the VB or C# controls. Use the File->Examples to load a sample project to start.
You can connect to the ARC via command line. View the Connection Control help in the ARC manual. Or click on the ? in the Connection control for a video help.
I can dl the ez sdk files and unzip them i just cant open them at all and what im looking for is a simple short 1 line code not looking to run it from the ARC just from the dos prompt/command line scripting it in c# or vb will be alot more complicated than it needs to be
There is no one line code for communicating through the serial port or a parallel port. Unless your thinking of just using a serial terminal to which you have to setup. For serial you have settings: baud rate, data bits, stop bit and so forth. A serial terminal allows for communications through a specified port but only if you enter the settings for the correct communication settings for the device attached to that port. This is how the ez-b communicates with your computer.
Egypt
#15
hey dj sures please help i need 6 new commands please please they are very important the one's in the first post
#16
@hamada you can connect to serial ports and input using the C# and VB controls within ARC. View the EZ-SDK documentation for assistance. Use MSDN for applicable Serial controls.
