Miscellaneous Utility Plugin icon Miscellaneous Utility Plugin — ARC utilities: DataQuery for SQL/ODBC/OLEDB/Excel with parameterized queries returning array variables; Ticks/Millis timing functions. Try it →
New Kit - Standard Servos Not Working
Hello, Received the kit a week ago. Updated the firmware, then connected over bluetooth. Attached the standard and modified servos to the motherboard. From the ARC tried to get the servos work by releasing and trying again changing from 0-100 on vertical servo controller. The four standard servos do not rotate. The modified servos working fine.
On the standard servos. i can hear the motor spinning but the little white part on the top is not spinning.
What is to be done?
Have you checked that you have wired the distance sensor correctly?
If you are sure it's faulty then you need to use the Contact Us page since nobody on the forums can help with replacements.
