Custom Movement Panel icon Custom Movement Panel — Custom Movement Panel maps directional commands to scripts, adjusts per-wheel speed (0-255), and integrates with joysticks for unsupported motors Try it →
New Product Updates
New Product Updates
As you know, I have taken a little time to distress and focus on what's coming for 2015. Yes, it was only a few days but it was my first time off in 4 years - and during that time I couldn't help but continue to work. Jeremie has been incredibly busy working with our manufacturing facility to get the new products pushed through the system. We finally have the prototypes (which are green PCBs and production will always be blue) of the following PCB's and more... that you have been waiting for.
I'm spending this next 7-10 days testing and tweaking code before they get pushed through into production.
Also, there is a rumor of some big changes to ARC . It's a large re-write of the entire software and therefore the new feature will be released in increments. The first beta version of the new re-write will be released this weekend. Without getting into too much detail, the new ARC includes the ability for C#, C++ and VB.Net programmers to build their own controls in the form of plug-ins. There will also be a monetizing "store" built around plug-ins which puts cash in your pockets for developing modules. The idea of the new plug-in system is to offload my development onto the community. For example, when you ask for a new feature request of ARC , someone can make it happen - and that someone doesn't have to be me anymore. Developers can create controls for new sensors, new apps, databases, games, etc... It's a real huge advancement that I am excited about.
So, jeremie had asked that I share photos of the new PCB's that he's designed. These are the green prototypes. Remember, all production PCB's are blue:)
8x8 RGB Array Display
There have been many requests for adafruit's 8x8 bicolor display. And well, I looked at it and was incredibly disappointed in the fact it's only bicolor and there's no control over individual gradients of each "pixel" led. If any of you are familiar with the 18 RGB LED Block, then you're aware of the amount of control we provide. So I've taken the same control and we designed a very amazing 8x8 rgb module with individual control of each led brightness/color as well as easy animation programming. Throw your adafruit 8x8 away because this is all that you'll ever need:)
New ez-b v4Camera
The new camera has some improvements over the previous ez-b v4. We have changed the lens to capture a wider image and the faster processor increases the framerate. I have written a new compression control algorithm which variably modifies the compression rate based on image size to optimize for high framerate. I have seen upwards of 28 FPS.
Line Follower
We joke that ez-robots are more advanced than the others because our robots sing, dance, respond to voice commands and more. However, all the competition seems to care about is line following. Well, we've never had that capability because it seems so 1980... Jeremie thought that we should at least provide that capability and extended it for new features. The sensor can also be used for gesture control, which was jeremie's idea. Of course it's a good idea but does require some tricky programming from me (Thanks Jeremie!:P).
Inverted Pendulum
Last but not least, you have all been wondering about the inverted pendulum. Well, due to ez-robot being a small team and that I have to bounce between positions such as janitorial, ceo, cto, developer, web developer, etc... I have had some other priorities creep up that pushed the inverted pendulum back a little. With the other hardware that I've listed here, i'm finalizing the code for production of this little awesome unit as well.
#17
@RoboHappy, What? Why would you want a bigger camera? Just because you have a very big robot doesn't mean you need a big camera. If it's just for looks get a bigger case to hold it.
#18
I've been 20 hours a day on this ARC re-write. It's coming along well - as with the new products. The camera is looking good and I believe we should receive our final prototype this week? Jeremie had sent it in last week so he might have a better date.
I'm making changes to the website for the assigned plugin GUIDs for ARC tonight. It's the first draft and not the final - but it'll give you an idea of what the plugin system will look like. Hopefully i'll have this first draft done tonight or tomorrow.
#19
DJ you've really got my attention on your latest efforts for plugin designs, can't wait to see what pops up.
#20
@fxrtst sorry I didn't get back to you, I didn't have a camera with me at the time. The new camera will be ~25mm tall as opposed to the older Camera add-on board that was 27mm tall. Sorry I don't have the final version yet but yeah it'll be a couple of millimeters shorter.
#21
Ok thanks that a great help !
