Set Digital icon Set Digital — Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only. Try it →
hi look on each page you see this mark (? ) click on that and you get a tutorial.
Thanks. I was able to get two moving at the same time.
am newbie too.your in the best place you can be.
Are you using continuous rotating servos? Look at using the modified servo Movement Panel then in your script you can just use the following commands to drive both servos(robot)...
forward()
right()
left()
stop()
reverse()
