Hi Think we will see the new boards by Christmas?
possum
— Edited
10 Participants
ZAMA Emotion Model
— Valence-arousal emotion engine generating persistent, configurable robot moods and event-driven emotional outputs for expressive behaviors.
The ezb v4 camera wire can be extended. I don't think you'll have a resistance issue.
That camera in your robot is neat. Nice that it has a composit output
Thanks DJ that is quite small, I'll make do. Sorry for the delay I'm in China at the moment. Getting super excited for the new boards and cameras! Keep up the great work.
is it possible to connect this camera on ezb4? blush
thank you
From what I'm reading the answer is no. Sounds like EZB V4 uses it's own protocol to stream the image back to ARC. However there may be ways to still use your camera with ARC but not directly through the V4 EZB. You still may be able to do it like we did with the V3 board and ARC. That way the image was sent back to your laptop via Bluetooth and ARC gathered the info through Windows as an installed device. I think I remember DJ saying we could still use our old cameras like that if needed but I may be wrong.
only the camera for sale on this website works with the ez-b v4, to my knowledge.
will there be other chapes availeble from the camera. excample like in the pic.
i need a flat one.
@Techno, I would say that any camera that is detected by Windows will work with the V4 since it will use ARC which already supports this. The V4 camera will only work with a V4 EZ-B since it plugs in directly to the EZ-B. This is for the PC version of ARC, the android and iOS versions will probably be different.
@nomad, you can use EZ-Bits to change the alignment of the camera. You will also (probably) be able to remove the camera from it's housing and make modifications to make it fit.
hi i dont have lot off space in the head.that why i need only the camera whithout housing.
