Pandorabot AIML2 icon Pandorabot AIML2 — Connect ARC to Pandorabots AIML2 to run AI-driven virtual personalities for human-like text or voice chat, using API keys and script hooks. Try it →
Newbie
:P
I have couple question about the kit.
If I have servos HS 645 can I use with EZ robot brain.? If I can than how many can I use up to ?
I am really interesting about using lipo battery? However if I use servo HS 645 than do I have to do any adjustment?
Last question, if I purchase I complete kit , which is include heavy duty servos. Are they same size as HS 645 servos?
Thank you.
Good point to know , thank you Allan. I will put it into consideration for future needs. For now, with some calculation 1EZB brain and 24 servos from EZ will cost me $388 stress eek eek eek eek Any deal ?
Get me if I am wrong.
The purpose for my bot would be autonomous exploring surround erea and processing the information to generate a map. Therefore the EZB program will provide me an environment to monitor the robot and magnet the information right ?
:P
Yes, ARC is quite powerful but at the same time easy to use.... Make sure you buy the camera too.... Then your robot can track colour, objects and even your face.... :)
You just missed the Cyber Monday 20% off sale, which would have helped a lot.
The developers kit comes with some servos (although 2 of them are modified 360 rotation, so may not be useful for your project) but also has a ping sensor and camera, so that has some built in savings. Also, the 3 servo arm or the "scorpion" kit has a built in discount. Basically you get the claws for free (although they are micro servos, and the servos you do get have the EZ-Bit plastics and don't have the original servo top, so if trying to fit in an existing chassis, possibly not a good idea).
If you have any existing robot, EZ-B is currently holding a contest for the best holiday themed robot video. The winner gets $200 in EZ-B credit.
Also, answering other member questions gets you $3 in EZ-B credit. A lot of questions can be answered just by being skillful using the search and playing with EZ-B software, which you can learn a lot of before owning an EZ-B.
Wow so many contests. I am so ready!
:D
PS I will upload some of my robot video later;).
Saving for EZ- B complete kit right now.
Do a little study about ARC, love it, however i only could read the manual for now but I already recognize the power of The Scrip.
The other day, i was sharing the goal for the robot. Today I have couple question for the educational goal.
My educational goal in this project is use invert kinematic . if I know the fundamental algorithm for body IK and Leg IK can i use ARC to execute it ?
I realize that invert kinematic to control robot, however can i use it for autonomous movement ?
For Example: if distance in front empty, use IK function to calculate the angle of each legs and execute moving auto balance moving forward ?
blush
If i get the complete kit, it come with rechargeable battery, however if i want to use lipo battery what connection should i purchase ? blush
i am planning to get the complete kit from roobotshop.com and order extra servos from the website ? or should i order everything from EZ-robot.com ?
i am extremely new to the programming field , so hopefully everybody don't mind about my newbie question,
#15
Any servos work with the EZ-B, but the EZ-robot HD servos are the most powerful for the price. The EZ-B comes with the power base (i think), which means any barrel jack connection will work with it. Just unscrew the base and you have a handy dandy little barrel jack-to-EZB power connection, which works from 4.5v all the way to 16v, so basically any battery within that voltage should work fine.
also - mind rewording that inverse kinematic paragraph? I would be glad to try and help but I don't really understand what you're saying :D
I'll just try and guess what you were asking about - yes, the EZ-B can use the sonar sensor included in the Developer's Kit to find it's way around a room on it's own. the Auto Position control can be used to reach a desired position, and then stop at a certain point and continue it's movement. You can read more about the Auto Position controls in the learn section, I believe. I'm not exactly sure about making it so the robot can autonomously detect a surface so that the legs would connect to uneven ground, but I bet it could be done somehow.
