Bing Speech Recognition icon Bing Speech Recognition — Accurate Bing cloud speech-to-text for ARC: wake-word, programmable control, $BingSpeech output, Windows language support, headset compatible Try it →
Stupid question... are you connected to the ezb when you run your script (a solid blue or green LED on your ezb4)? Does this work... Say("I am a human") play through your PC speakers?
Yes I am connected to the EZB and the other parts of the script run OK. No speak thru the EZB or the PC. I want it to play thru the EZB
Hmmm then it's not a faulty ezb4... Speech doesn't seem to be loaded.. Has speech ever worked out of the ezb speaker or your PC speakers before? Try the easy things first... save your file, close ARC and reboot your PC if necessary... Then try again...
Are you getting any messages in the DEBUG window of ARC? It will pop up with messages. Look in it - copy and paste to us as well.
I'm not getting any error messages. I have set this project up on and I am connected to Board 1. Is there a setting somewhere to send everything to Board 1? I have the Auto Position set to that board.
audio only comes out of Board #0. Why are you using Board #1? What is connected to Board #0?
Oh Man... I was just about to ask the same question, but I was hesitant as figured it probably wouldn't have any relevance on why the audio wasn't working.... Something else I leaned today... Thanks DJ....
Another good example showing how important it is to give as much detail about a problem you are (I mean everyone) having... Sometimes the answer is in the smallest detail....
Well, there you go! Did not know that audio only comes out of Board #0. Thanks DJ and Richard, I switched everything out to Board #0 and the audio is working. Dilemma Resolved !
