How do I activate a soundboard track from the Speech recognition ?
I thought it was as simple as writing in Track_0 under the command to activate the loaded slot on the board but no luck.
I'm sure this is easy but can't work it out.
Robotis Openmanipulatorx
— Inverse kinematics for Robotis OpenManipulatorX: compute joint angles and MoveTo 3D (cm) positions, supports camera-to-CM mapping for pick-and-place.
Take a look at the Wall-e Big example in ARC
File -> Examples -> Robot - Wall-e Big
