can i use speech recognition from nuance for ARC.will that work? on win7.i dont want to use my pc whit my voice just will ARC recognize, the speech engine.
thanks anyone
Intel Realsense T265
— T265 VSLAM for ARC: SLAM-based mapping and precise way-point navigation, low-power tracking, and NMS telemetry.
thanks anyone
What language is your computer set for? You may need to install the language.
ok i found it.am downloading englich language on win8 now
than you guys
dj
What language would you prefer? Maybe your language is supported? Belganese
dj no only en-US the language is set also the mic. can you give me little excample what it can do.?
@nomad see where it says "Robot move Forward".... When you speak that your robor will execute the command Forward() (in the right side script)...So in the left side of the column you type in the command you want your robot to do... For instance.... "JD stand up" in the column beside it (right side) you type in a script or you can use ControlCommand to make your JD pose or do whatever... In this case you can have JD Pose by standing up straight.....
You can put as many voice commands as you want... The command that you will speak is on the left side... On the right side the script you want to run when you say that command....
rr
it doesn work.do i need speech recog for that?
In the above picture you posted it shows you do have it... en-US .... You will need to use English... Does your Win8 PC have a microphone built in? Go to your control panel on your PC and look for "Speech Recognition".... If it's there then you have it...
ok i have to set the pc in englich language.i saw setting for speech recog. i use headset
