My question is there a way to install a raspberry pi zero with a with a webcam on it and be able to connect to it with ARC? If so what is required to make that happen?
smiller29
OK Can You Use A Raspberry PI Zero Webcam With ARC
Raspberry Pi
by Pi Foundation
Synthiam ARCx runs natively on Raspberry Pi 4/5, controlling robots via browser with EZB controllers, vision, speech and scripting.
Servos
UART
ADC
Digital
Install one of the two firmwares for the pi. I think the blueberry is preferred: https://synthiam.com/Support/Hardware/Raspberry-Pi
*edit: your title question says "ok". Does that mean you solved it?
Ok I found my own answer and if anyone wants to do this check this video out.
The software can be found at for the Raspberry PI https://piwebcam.github.io/
