Does anyone happen to know of a good off brand micro servo replacement for EZ-Robot Micro Servo ?
I assumed it might be compatible with 9g servos but I was wrong. The 9gs are too tiny to fit in housing for the micro servo lever for the JD head.
TCP Client
— Telnet-like ASCII TCP client for ARC: connect to IP:port, send ASCII, view raw or HEX server responses with local echo
why you want to use another servo then the original?
Because I'm making new JD heads and I've printed the brackets for the neck lever but my micro 9g servos are too small and I don't want to wait weeks and pay extra for shipping for a servo replacement I should be able to find a replacement for.
I want JD heads I can swap from the neck up.
am happy to donate for a original or one you prefer servo,you did all the work and put your , material and time in it.am sure there will be others too.
That's very kind Nomad, but not necessary. I just want to know what an off brand replacement servo replacement would be, make and model.
The standard HD servo was originally MG995 servos, so I assume there was an off brand micro servo originally too.
here the page for 3d printing below is something you can use ? its an stl from a servo mini.
micro servo
No, I need a real servo. I know about the .stl blank for the servo. I'm looking for a real one.
With some help from someone who pointed me in the right direction, I came across this which seems to have the right dimensions. https://www.sparkfun.com/products/10333
i messure micro servo original L 28.8 D 14.3 H 35.9
here the size original.
