Community Robot Questions Omnibot 5402 Arm Length CardboardHacker Canada Asked Jul 2013 — Edited Jul 2013 1 Participant Rich Omnibot 5402 Arm Length ARC Skip to comments Jump to end what is the length of the omnibot 5402 right arm? interested in frankenstiening up my rad project AleX Quote Jump to end Upgrade to ARC Pro Stay on the cutting edge of robotics with ARC Pro, guaranteeing that your robot is always ahead of the game. Compare Pro Features View Subscription Plans Rich United Kingdom #1 Jul 2013 The whole arm or just the top or bottom sections? I know that either the whole arm or the upper arm is 300mm long roughly. They should just about be the right size on a RAD. If you look in this picture you can see the RAD is around the same size as Melvin, which is basically a 5402 torso Reply Quote Share CardboardHacker Canada #2 Jul 2013 ok thanks. theres a guy who tore his omnibot apart and is selling it for parts. hmmmmmmmm.... eyeroll Reply Quote Share Rich United Kingdom #3 Jul 2013 Omnibot arm next to RAD torso You decide Reply Quote Share CardboardHacker Canada #4 Jul 2013 wow! there bigger than I thought! how big is the omnibot 2000?!?(not the arm, the whole robot) Reply Quote Share Rich United Kingdom #5 Jul 2013 That's from a 5402, the 2000 is bigger. It might work with the 5402 arms, just make sure they bend at the elbow before lowering the arm down otherwise they will hit the base. Reply Quote Share CardboardHacker Canada #6 Jul 2013 yea. I think I will try to use a different arm. I learned one thing, and its that I got the small robot. Reply Quote Share Login to post a comment
You decide
