Sphero Movement Panel icon Sphero Movement Panel — Control Sphero via Bluetooth in ARC. Detects two COM ports (one connects); requires deleting and re-pairing after disconnects or reboots. Try it →
Omnibot Front Panel Dimensions
Does anyone have the dimensions, or better yet a 1:1 PDF/DXF/DWG/PSD/JPG/Whatever of the front panels on the Omnibot chassis? (Tape deck and clock areas)
I'm about to start designing my new front panels, I have no problems measuring and drawing up what I've asked for but since it's late and the batteries in the keyboard on my PC with AutoCAD on have died I wont be getting on to it until tomorrow, but thought I would see if this already exists to save doing something twice.
Feel free to provide any measurements you may have, measure twice cut once and all that:)
You could have shape ways.com print it for you , maybe a bit cheaper. , very cool find on the front panel company. What do you want t to fit there?
I don't have much other than the LCD Display which should take up most of the top one (going by data sheets, I don't have the LCD for this one yet).
Then only the on/off switch (if I put one in), ping sensor and IR sensor in the lower one. Plus some decoration to match the existing decoration maybe, that's when I'd want it done professionally.
Thank you Rich, this is perfect. I tried to do one myself and it wasn't quite clean enough for me. This will be perfect!
A tip, don't use superglue to fix the panels if they aren't complete... My top panel wont budge for love nor money (it's obvious really but just thought I'd share in one of my fails).
If anyone plans to use Front Panel Designer here are the templates attached. I guess they would do if planning it out too.
panels.zip
Double check all measurements I make no guarantee they are right until after I've done a print and tried it out.
Edit: Oops... Measure twice cut once and all that... Just did another check on the measurements and it looks like the top part of the lower panel is 5mm too short, it should be 12mm not 7mm. So just be aware of that.
