Anyone managed to hook one up to the EZB yet ?............just curious.
nanomole40
— Edited
Command Duplicator
— Duplicate and synchronize commands from one master EZ-B to multiple slave EZ-Bs for simultaneous, mirrored robot actions.
Ok thanks David.
@CochranRobotics
Hi David, I have recorded and stored some faces using my new sensor/camera. I used a folder as requested by the HVCDemoE software that is supplied by Omron.
Have you found a way to use the facial recognition thru the plugin yet?
Thanks,
The plugin does facial recognition on the V1. What it doesnt do yet is record a face to the database from the plugin. Right now, you have to record the faces using the omron example app and then copy over the text file. The way the omron works is that it returns an ID of the face. The plugin looks for the name associated with that ID in the text file and returns that name. I havent had a chance yet to try out the V2 with their new software. I assume that they have made a change to the text file, but I havent had a chance yet to look into the new software.
The facial information (Album) is stored in a folder called " HVCAlbum.hac ". I currently have it located in my Document folder. Should I move it somewhere else or how do I point to it?
can you copy that and email it to me? i will see if the foemat changed with the new version.
I will first try a reload of the software. Maybe I corrupted it messing around with the album for the facial recognition. I will let you know how I make out. I wasn't sure you had gotten the recognition part working in the plugin. Now that I know it is okay, I will see what I may have messed up.
Hi David, Hi Andy,
With Version 2 David plugin also work!
Only the Names what i save with Version 2 are not shown in Davids Plugin!
You must use the old Software (But you can use the new Camera/Board) and all works.
Only if you use the new Software you will have Problems with the saved Names of the facial recognition.
But this i told David.
https://synthiam.com/Community/Questions/10350
Boris
The Omron seems to be hot gossip again... time to take mine off the shelf!
Its been sitting there since I realized it could not be returned and changed for the newer version! So I guess I should get started now...
