howmany amps is the on/off switch from jd?
anyone knows this?
THANKS
Tiny Yolo2
— Real-time TinyYolo object detection for ARC Camera Device: tracks 20 classes, populates camera variables, triggers tracking scripts, 30+ FPS in HD.
dj
the mad B scientist hehe
dave
switch is 12 volt, 6 amp ,i dont know howmuch the switch off jd is. i only know all pics are for 12 volts.
for hercules poirot is sure as ugly as me, haha
6 amps is pretty good size. Just remember a electrical circuit is only good enough to handle as much as it's lowest rated component. As an example; Lets say you have a circuit with a switch rated at 6 amps and wire connecting everything that is rated to carry 10 amps but have a 20 amp fuse installed You should only install equipment that pulls no more then 6 amps through the circuit. Also the 20 amp fuse would be useless and should replaced it with a fuse that is rated at 6.5 or 7 amps.
As far as Hercules; he does have a cool looking mustache. Don't know what you look like but maybe a "stach" would turn the ladies eyes your way. If not I love this quote from a great Canadian philosopher named Red-Green. This advice has worked for me all my life:
"If the woman don't find you hansom, they should at least find you handy".
dave
its an original jd robot.
well the ladies find me very handy in averythng...............
i wasn content with the cable male&female jack,to thin.but i found one 5 A also i found on ebay 2200 mah original batt we use here. am gonna use the ez mip for this cause he will allreddy use power, to keep standing up.
new cable
first cable
