Video update 7-10-2013
problem fixed!
Continuous Servo
— Control a 3-wire continuous 360-degree servo in ARC: adjustable forward/reverse speeds, start/stop buttons, board/port selection and test controls
problem fixed!
Lol I meant capiche...
Good question. Mine have done that since day 1. I'm new to robotics and EZB so I figured that was the normal reaction due to the initial power up. Or a response to a connect request signal or something like tcp. confused
The while project would be pointless if lithe servos freak every time it connects.
Come on guys, you've either figured it out ( and not telling us) or we all suffer from the same situation.
And I choose not to belive that.
Help us.
First off, i can't even begin to tell you how disappointed i am in your language and tone. You are not honoring the culture of EZ-Robot. What has caused you to think that you would need to swear and be so rude in order to obtain help?
As you can tell, i'm not helping you until you apologize. Next time this happens your account and ip address will be banned.
I had this problem and solved it eaisly. There is a lot of posts about it and I along with others listed solutions. Do a search and you should find ways to fix this.
Hopefully you were under the influance of something when you made that awful post only a few hours after your first and after you correct this you can be a wecomed member around here.
Dave Schulpius
I must have read the post after the edit. I just saw the question and I never thought to ask it. I apologize if I jumped into the wrong band wagon
I figured it had to do with the initial voltage running through. I'll try another search. I can say that the EZ forum search forum is one of the only forum searches I've ever used that actually gives decent results.
Once again I sincerely apologize if I've offended anyone or crossed any lines. stress I love the EZ community
OK EVERYONE CALM DOWN...
were not all super smart robot people here....sometimes I speak with bad words (most people online do) look at all my other post, and im super cool.
wasn't talking smack about the ezb or the reply...
I was just saying f that, I need to figure this out....I know most of you are super smart and look down on that language, so ill check my self
sorry. we good now?
Also, I have searched, again not smart so im looking up phrases like:
servo position on start up servo initial connection position servo unwanted movement
Everything I find is on auto connect. but im assuming thats for the board connecting to the software. not the servos getting power.
