Continuous Servo Movement Panel icon Continuous Servo Movement Panel — Control two continuous servos for bidirectional robot movement with speed sliders, configurable ports/stop values, testing and brake/coast options. Try it →
Only 1 Speech Recognition Control ?
Hello Im have many scripts in mind but ARC only allows 1 speech recognition control:( It would be vary handy if we could use many speech recognition controls that we could rename That way we can have sets of speech commands that can be turned on and off when needed
I know there is the SayWait command but that is vary limited as to what it can do plus it is on a timer and pups um a list on the screen that is not wanted a lot of the time
With being able to have many speech recognition controls we could create much better AI scripts with ALOT less coding and way less work arounds that in many cases just will not work
I can scripts with groups of commands in mind but that takes a lot of extra coding and many times when adding new commands I would need to go back and add more lines of code to other commands
I have been thinking about this for over 2 weeks now trying to think of ways to get around it but the best and most simple way would be to have it so we can have many speech recognition controls in the projects
To script for groups would take 2 extra lines of code per voice command plus a simple one line script which sets a variable for the group.
Script 1, to enable the group "daytime"...
$daytime = 1
Script within the "daytime" group
IF($daytime = 1)
  # Commands in here
EndIf
The voice command script in the "daytime" group will only run if $daytime = 1 If it doesn't then it wont run.
Use whatever you like to set the group to on or off... for instance
:loop
IF($hour > 8 and $hour < 18)
  $daytime = 1
Else
  $daytime = 0
EndIf
WaitForChange($hour)
Goto(loop)
Or even a simple
$daytime = 0
and
$daytime = 1
set to voice commands.
Sure, DJ could probably add in groups to the existing voice command control however in the mean time there are always ways around it, you just need to think a little:)
I know how to script for groups have scripted for groups for many many years now but every time I add a new command that is the same as another that does a different thing I will have to go and add more lines of code to other commands
I tend to think a lot and I mean a lot lol I always try to think of every thing that can make a script work and what will stop them from working and what can cause problems down the road If we could use more than 1 speech recognition control at a time it would save ALOT of scripting ALOT of headaches and make AI scripts ALOT more dynamic
It should not take much at all to get ARC to allow more than 1 speech recognition control as most of the code for it is already there just need to set it to allow more than 1 at a time and to have it so we can rename them
I responded to your comment:
2 lines of code, one at the top of the script and one at the end is not a lot of extra coding, this is all that is needed in anything which requires enabling by anything.
I cannot see how adding in 2 lines of code, right at the top and at the bottom of any script is a lot of code, headaches and everything else you claimed it to be. It's 2 lines of code in 2 of the easiest places to find in any existing script.
Taking up additional screen real estate and more than likely more processing resources is not the best option in many cases. Generally, where DJ has limited the controls to only one of that type there is a reason. A solution is to script the 2 lines of code I mentioned.
Grouping is not limited to voice commands, I use a lot of grouping for many different controls. Therefore to add it to one control, while a solution, may not be the best solution.
If you're unwilling to accept help when given it or unable to see solutions offered with an open mind when they don't fall exactly on your idea I will have to fall back on my previous statement made to you in a different topic and am unable to offer my time to you.
I can see you just don't understand what im saying and I cant explain it to you any better:( the more commands I add the more lines I have to add to older commands and the more complex a script gets the more that needs to be added to other commands
Im not dealing with simple little scripts im dealing with big mager scripts that just 2 extra lines will not do the job
Why is it every time I make a suggestion that will make ARC better and a lot easier to use it causes a big problem:(
I give up i will never make another suggestion again:(
Wolfie, I won't let you leave;) you're an important part of our community.
As for more than one speech recognition - it's impossible. The windows API and ARC design doesn't allow it. Im unable to type on my phone the technical reasons why right now.
I would recommend using the AI module we have, or writing scripts:)
Sorry to break the bad news
The two lines of code I posted will enable or disable any script or part of script. Adding them to any script would not be difficult regardless of it's size of complexity. If there is part of a script you don't want to be run under certain circumstances surrounding it with an If and EndIf will give you that control over it. I use this method a lot with Melvin to enable/disable certain actions, behaviours and controls based on time of day, day of the week, month, temperature, previous actions carried out, information Jarvis feeds to him, and his mood amongst other things. I can assure you it is as simple to implement as I have explained and works very well.
I understand exactly what you are saying, you want groups of commands that can be enabled or disabled. What I don't understand is how your proposed extra voice controls will make current scripts any easier to have such a control over. If my suggestion wont work your suggestion, or at least how you think it may work doesn't make sense.
I don't want to discourage anyone from asking questions or posting ideas however when I take the time to provide a working example of a solution that's instantly dismissed because it's not exactly what's been requested that's how a problem is caused. We had a very similar situation in a few other topics recently (email and controlling a switch to name two from the top of my head).
If you don't believe the solutions I have posted would work at least provide details of any errors in them which you have encountered. However if you're unwilling to try solutions I have provided or unwilling to provide detailed responses relating to errors or problems implementing them then I am wasting my time which is something I would rather not do, if that's going to be the case tell me and I will leave it for others to attend to.
Hang in there, Wolfie. No-one meant any harm. He just asked you to have an open mind. That is easy for me, cause my mind has a big hole in it, ha!ha! It's all good!
Lol, that makes two of us. My mind seems to be quite forgetful lately! Trying to pack too much in my little head
